Can't decide whether to get the new 13" with 16gb ram and 512gb ssd or go for the 15" with 460 gpu
I've narrowed down the deciding question to.. How much difference does a 4 core CPU make for web development work? Or in what situations would I feel that 4 core CPU difference? Would it help running a vagrant or two plus windows in vmware, and 2-3 IDE's?
My logic, is this;
Based on the Ars review, the only material difference in performance between the different versions is whether you get a 4core CPU or not. http://arstechnica.com/video/2016/11/the-2016-13-and-15-inch-touch-bar-macbook-pros-reviewed/
Those are all in benchmarks suites though. How much software is actually optimized for more than two cores today?
That, and GPU. Yes, I would like to be able to game, but I can buy a dedicated system for the difference. Touchbar? I know my shortcuts already and it's another thing that can break.Portability of 13" vs Niceness of having 15" are of equal value to me, so can give or take either, I'll mostly have it connected to one of the new displays.
I don't mind spending the money per say, but I believe because of the RAM limitation this machine will feel limited sooner than I'd like regardless - so I might as well save money.
My logic, is this;
