Barton temps too high?
paco83
I have a barton 2800+ OC'ed to 2.3 ghz on a 8rda+ and it seems to running on the warm side. My case temps are around 32-34 (ambient is around 80F), and my cpu temp is about 51 load when i have the TT SF II set on temp control mode (sensor is right next to the chip) and about 48ish load when the thing is on full blast. I think i have pretty good airflow, 2 intake at frton bottom, 1 exhaust and 1 pci slot cooler to help balance the airflow. Anyone else with a similar setup getting temps around this or are these high? I've reapplied AS3 and SLK-800 a couple times, and this is the best i could get.
Edit: Forgot to mention vcore is 1.8 (1.825 actual) and Vdd is 1.79
Compare your results to the factory settings of the CPU...expect a rise of 5 deg C when you raise the voltage and overclock.
51deg C seems fine though...I would set your comp to turn off it it climbs above 60 deg C though.
The reason I say this is that Thermo sensors are FAR from accurate.
Better safe than sorry.
Tuff
