I can't figure it out. This is the heatsink/fan I have (5500RPM fan): http://www.explosivelabs.com/reviews/copperx/index.shtml
I know it's not the best, but 80+ C under load doesn't seem right! I'm using plain white thermal compound, and it's applied correctly. Do you guys think a better HS/Fan will clear up this problem?
How about this one: http://www.newegg.com/app/viewProductDesc.asp?description=35-103-407&catalog=23&manufactory=BROWSE
It's recommened by AMD up to 3200+ so I would guess it should work good better than the crap I have now.
Thanks!
Thanks!
