I need to bounce something off all you bright people. I am putting together a system for a friend. I purchased the following: Gigabyte GA-7N400-L motherboard (refurbished), AMD Barton 2500+ processor, 512MB of Muskin PC3200 memory (1 stick), & a Thermaltake Silent Power 420W power supply. My friend had a case, harddrive, and CDRW that we are reusing.
HERE IS THE PROBLEM: I put the system together and I was having problems detecting the proper CPU and it took forever to autodetect the IDE devices. I could not get it to boot to the CD-ROM. I went into the BIOS and loaded optimized defaults and that solved the CPU detection. It now detects the Barton 2500+. I was unable to boot from CD and the system was acting unstable. I checked the CPU temp and it was at 65C. I looked over the retail CPU fan & heatsink and all seemed fine. So, I pulled the heatsink, cleaned everthing up, reapplied a thin coat of thermal paste, and remounted the heatsink/fan. No luck...the system seems to be quick to the Bios after it sits for a while, but quickly heats up and becomes unstable.
I have installed many AMD's with retail heatsink/fan without any problems. Since the motherboard is refurbished, I have a short time to get an RMA. Any ideas on what the problem might be? I am about the RMA the motherboard and see how the rest of my stuff works with a new mobo.
Help... I would like to thank-you in advance for providing me your opinions.
