- Jan 30, 2001
- 2,060
- 0
- 76
Hey all, I picked up a barton 2500+ and was running it stock at these speeds on my 8rDA+ latest bios. My ambient is 28 degrees, so isn't this chip running hot? I'm using AS2.
I've since OC the chip, stock voltage, stock cooling still, to 3200+ speed swith the 200mhz fsb, and idles 47, load is 51. I'm definitely happy with the fairly cool OC, but aren't these temps high? Does the newer bios record heat higher then it actually is? I'm sure everything is seated correctly, and the AS2 is definitely put on right... I've done dozons of these.
Oh, and before anyone asks, stepping: AQXEA 0323 . Seems to go up to at least 2.3 with stock voltage, may actually be my mobo stopping me from going higher as my 8rda+ is revision 1.1
