Could just be IHS to DIE height related instead of TIM. Unfortunately you will first know what of the 2 reasons it is when you delid.
I'm tired of replacing the TIM under the IHS on my 3770k because of TIM failure under it. Does anyone know if a bare die mount can suffer the same effects?
(which will most assuredly rip-out the die if you attempt to unmount)
My IHS sits directly on my die. One of the first things I did was get rid of the excess rubber adhesive, and sand down the height of the IHS "legs" (ok, not legs since it's a solid square, but that explains it) so that it is really just a plate that sits on the die.
