Bakers: Any difference between Belgian and regular waffles?
Frosty3799
3,795
different stuff in them.
For example if you buy a belgian waffle mix, then it will tell you to just add water/seltzer water, while if you want to make traditional waffles using said mix, it will tell you to add egg, butter, and a few other things too.
FoBoT
63,084
15
fobot.com
i think it just depends on where you are when you make them?
really i think it refers to the depth
belgian waffles are the really fat / thick ones
Excelsior
19,047
18
Thats how I think of the difference too.
