i have some brake dust that's been practically baked into my alloy wheels. what's the best way to get it off?
i used some engine degreaser and a wire brush that seemed to kinda do the trick, but i ended up wearing out the brush after half of one wheel. is there an easier method? can i use some kind of solvent or something? are there wire brush cleaning drill heads?
