bad psu
jhill1
95
ok i will
i think ur right, because everytime i try to open my essay, the comp locks up... is this most likley a cpu problem
jhill1
95
it hovered about 50-51c when i left it completeley alone
heres my voltages, they didnt change much when i put in the other psu. only about +/-.02
Navid
5,053
Right click on "My Computer" and click on "Properties".
On the window that pops up (System Properties), under "Computer:", what do you see?
jhill1
95
computer: amd athlon 64 x2 dual core processor 3800+ 2.01 ghz, 2.00 gb of ram physical address extension
Navid
5,053
Good.
Download CPU-Z and run it.
http://www.cpuid.com/cpuz.php
On the CPU tab, what is "Voltage"?
What is "Core Speed"?
On the "Memory" tab, what is "Channel #"?
What is "Frequency"?
What are the timings?
jhill1
95
i already got it but it says:
the voltage keeps going between 1.216 and 1.232 even though in bios i have it set to 1.325
the core speed is between 2006-2008MHz
channel # is dual
freq. is 334.5
4-4-4-12 then it says 19 and command rate is 2T
Navid
5,053
Is there any process on the "Processes" tab in "Task Manager" that is taking the CPU time?
Navid
5,053
Hit Ctrl+Alt+Del.
Select the "Processes" tab on the window that opens up.
Look under the column titled "CPU". Is there any process other than "System Idle Process" with a number higher than 5?
Navid
5,053
How much virtual memory have you got?
How much free disk space have you got on your XP drive (percentage)?
Navid
5,053
Right click on "My Computer" and click on "Properties". On the "Advanced" tab, click on "Settings" under "Performance". On the "Advanced" tab, you can see "Virtual Memory".
Navid
5,053
I'm afraid I am out of ideas!
If the issue was the lockups, you could run Prime for 10 hours to make sure that it would not stop because of an error and if it did, you would have to improve cooling for the CPU.
But, your computer being sluggish is a puzzle. This does not make much sense to me.
I suggest that you make another post in the "General Hardware" forum. There is more traffic.
Make it short and to the point and ask for help. I am sure others will help to figure it out.
jhill1
95
thanks for all your time and help. ill definatley go post there and maybe ill try other websites?
