Okay, first, here's my hardware:
ASUS A8N-SLI Deluxe
AMD Athlon 64 X2 3800+ [512 KB per core]
Stock AMD CPU Fan
OCZ Platinum [Rev. 2] Dual Channel 512MB x2 (1GB total)
ASUS Extreme AX850 Pro (PCI-E x16)
Western Digital Raptor 74GB x2 (NVRaid Stripe)
Antec TruePowerII 550 W
Logitech Z-5500 Digital (connected via RCA Coaxial to onboard audio chipset)
Second, here's my problems:
1. Warcraft III sometimes becomes choppy and the mouse scroll becomes erratic.
2. When certain light switches in the house are turned off, the speakers pop.
3. Occasionally shortcut icons become the generic icon for the type of file they link to.
4. USB ports do not output enough power to run the wireless keyboard / mouse.
Third, some relevent system information / troubleshooting steps.
a) Updated to latest MB BIOS (1017.004), which made no difference. CMOS defaults make no difference either.
b) Reinstalled Windows XP about 5 times. That doesn't help.
c) Plugged surge protector into about 5 different outlets in house. The speakers still pop.
d) Put electrical tape between case standoffs and motherboard, per advice by tech support at ASUS. No problems resolved. Also per their advice I verified that the amperage on all the power supply outputs is sufficient.
e) Reseated graphics card. No difference.
f) Monitored CPU temp. It idles at about 100 degrees F at seems to max out at about 120 degrees F. I have a Thermaltake CPU fan which never got installed because the AMD warranty is void if the right thermal paste is not used. I don't know anything about thermal pastes.
g) Ran 3D Mark 2006 Demo. No hangups. Scored about 1800 marks.
Lastly, I just want to say that I'm not very knowledgable about PC's, so if you decide to try to help, please explain in detail the steps I must attempt. My last resort (which probably should have been 1 of the first) is to spend about $200 on a 600 W UPS, then RMA the motherboard and read a bit about thermal paste before the new one comes back.
Thanks and good luck to you all with your systems.
ASUS A8N-SLI Deluxe
Stock AMD CPU Fan
