- Oct 22, 2018
- 3,348
- 1,576
- 96
Alright so i recently got this little 2000 Corolla and while it can run nice when cold it starts to misfire at operation temperatures especially under hard acceleration. Had a misfire on cylinder #4 so replaced coil and plug with factory oem specced ones.Car runs better now but still got those misfires. Cleaned PCV valve and throttlebody so i cleared most of the typical stuff. Even replaced the throttle body position sensor as well. Stuff was cheap enough so why not on a motor with 210k miles and a questionable repair history.
Decided to inspect the crankshaft harness as i hear these can go bad and i found a exposed what i assume is the ground wire showing. Insulation more or less has fell apart and off quite some time ago minus a bit that came off with a slight touch of course completely covered in oil dirt and grim. I figured today maybe i could clean it and rensulate it and attempting to remove the harness gently resulted in the ground more or less falling out of the main harness.
I assume if this ground was on the harness it must have been on by a hair giving just the slightest amount of ground. The wire is tough so i got is perhaps something in the undercarriage just gave this thing a good tug some time ago and me just fiddling with it just up and destroyed it.
So what do you guys think? Yeah i am replacing it but what are the odds its been causing this misfire?
