Car doesn't seem to charge right. Took it to advance and had it tested and tested bad. Took the alternator out to have it rebuilt and the guy put it on a tester and said it tested fine throwing 14amps. Well then since the belt on my car makes squeaking noises often I figured I would change it since its cheap anyway. Well the belt fixes the squeaking sound but not the alternator problem. So now I am thinking the battery might be bad?
I have a tester myself and with the A/C and headlights on it tests anywhere from 40-60 percent out of 100. I put the same tester on my sisters mustang with A/C on and headlights and it stayed above 90 percent. Could it be that the battery although it seems fine? Could have a dead cell or something? The green LED on it shows green and my tester shows it throwing 12v.
Any ideas? Its a Pontiac Grand Am SE 2000 model. BTW if nothing is on(A/C,ect) my testers shows around 80 or so. Also the engine sounds bad with the A/C on like its not getting enough power.
