- Feb 4, 2009
- 35,862
- 17,407
- 136
Seems like a simple job however I have an analysis paralysis problem.
I have sanded the wall, I plan on using some simple green or ammonia cleaner to prep (wife has a problem with tsp so that will not be used).
Do I need to prime the wall before applying the thinset & tile to the wall?
Something like this:
Example of sanded wall, we used an egg shell finish on it about 9 years ago.
Wall is mostly smooth and per a level the countertop is level.
I haven’t checked the cabinets however there will be about a 1/2 to 1” gap between the top tile and bottom of the cabinet. I am not concerned about that small gap it will almost never be seen since our kitchen does not have a table.
**strange line in bottom right of picture is a camera artifact or something it is not a crack**
***this is not the wall with the sink, it does have the oven. Oven is the only spot where is could come in contact with steam/moisture***
