Seagate drives are just crap compared to WD.
Seagate are unreliable and cheap, wouldn't trust my data on them.
-snip-
Did those cheap drives also come with a different MTBF from their manufacturers?Here are the facts as far as have been reported by both Backblaze and the various tech sites.
Backblaze by their own admission buys in harddrives based on price with no other consideration being paramount.
Did Seagate or any other manufacturers warn customers of reliability concerns due to the floods?Backblaze by their own admission bought Seagate drives alost exclusively during the harddrive crisis after the floods because other manufacturers were not able to supply.
Are USB drives more prone to failure under certain temperature/vibration conditions? Are they significantly different than other retail drives from the same manufacturer?Backblaze by their own admission buys in external USB drives to take them apart.
Can you please clarify this statement?Backblaze by their own admission stated that when they could use the drives even after they had been deemed faulty in a single drive environment.
Why? Did they lose data? Did they end up spending considerably more money? What damage has been done?Now to my mind whoever was/is responsible for purchasing mission critical equipment at Backblaze is criminally irresponsible.
However, you know little about the PSUs being employed. Are you suggesting they use bad PSUs wit Seagate drives and reliable ones with other HDD brands?One thing which I have not seen in any reporting is what kind of Power Supply Units they use in their drive farms. If they use the same kind of criterion there (cheapest possible) then what surprises me least is the amount of drive failures they have had but rather that there have not been even more.
So they bought faulty Seagate drives to begin with?Backblaze has bought in higher end Hitachi drives when the price has fallen due to the introduction of newer model. They buy in newest models Seagate drives because of capacity and price irregardless of the STATED USE by Seagate.
You already mentioned this, did anything change since 5 paragraphs ago?What I find horrific is that in a so-called "professional" data storage company they get a high percentage of their drives from breaking apart external USB drives.
Are you suggesting a VW Golf engine is not reliable enough to work as a tractor engine?It's like there was a dire need for engines, so they bought a few thousand cheap VW Golf cars, stripped the engines out of them, bunged them into tractors and then turn around and say that VW is crap because so many of the engines they built into the tractors failed under load.
But did they blame anyone? Seems to me you don't realize what they've been saying all along with these reports: it's cheaper to use cheap drives. They use more drives to achieve the same reliability, but they still end up paying less. This shouldn't happen with properly priced enterprise drives.If Backblaze is too effing stupid to use the right tool for the right effing job then they cannot blame anyone but themselves.
I reported your post and here is exactly what I said:
If you are going to have a go at me then at least try to make a cogent argument instead of taking your intellectual cues from the likes of Faux News.
And please tell me where you see "8x5" specified with regard to HDs. Again another claim I cannot see verified anywhere.
What you seem to mistake is "being available 24/7" (powered on but not spun up) with "being accessed 24/7" (powered on and spun up).
And yet, after that entire nonsensical rant, the other brands did better under identical circumstances. How exactly is that Backblaze's fault?I am a bit cheesed off about seeing posts using the reporting of Backblaze to paint Seagate harddrives in a bad light.
The only (on topic) reason why I might be inclined to question a sysadmin's competence when picking drives for such a scenario as Blackblaze's (as I understand it) would be if the person had been picking drives that the manufacturer had clearly marked as something like, "this drive is not designed to withstand stress caused by running 24x7, running it in such an environment will void the warranty and cause the drive to fail prematurely", which is a warning I'm not sure I've seen before on a HDD, possibly because (at least in my experience), HDDs tend to be more reliable if they're not being spun up and down on a regular basis.
You'd think they would rejoice such test results were made public of a real world case involving a huge amount of drives, but nope, it's the opposite reaction from people like Nec_V20 who seems enraged about it for some reason. If you're going to rail against Backblaze, why not take aim at every tech site including Anandtech who uses results from extreme, out of spec testing?
It is awesome that the data is available. I for sure think more highly of certain Hitachi drives than I did.
The problem is when the data is used to extrapolate things that aren't true. Like just because one Seagate drive model is bad then ALL Seagate drives or bad. Or heck, even just because the 2011 versions of that drive were bad doesn't mean new ones are. The first 3TB Seagate drives had five platters, current ones have three. Product and product lines can change over time. "3TB Seagate Drive" could mean a dozen actual variations within a couple of models.
Also, keep in mind Backblaze publishes new data periodically, so with new data sets we are likely to see newer Seagate drives return to normal as far as failure rate is concerned.Enter Backblaze data. I can look at large samples of drives from multiple manufacturers, all used under the same high stress environment, thus removing external factors. I can clearly see that the 3TB Seagates have a much higher failure rate than WD, Hitachi and possibly Toshiba when used in the same environment. Now I can decide if it is worth it to pay $75 for the Seagate or get what is probably a little better HGST or Toshiba for $10-20 more.
I don't know how it could be any more clear that 3TB Seagates are more fragile than their counterparts. I wouldn't pay the extra for a 3TB WD Red, either. That doesn't mean they will fail when used as directed but I can decide not to take the chance and I don't. It is worth a little extra investment to get the drive that is much less likely to fail under stress.
I find it interesting how some want to disregard Backblaze's findings due to their beyond the specs use of the drives. Aren't extreme tests and benchmarks what geeks pay the most attention to when hardware tech sites do their reviews? This is the same community which prizes overclocking right?
+1
What I find most interesting is that the anomaly that caused the failures is still unknown, to us at least.
The reason the drives, or a certain population of drives fails, is never explicitly expounded upon in the BB data; BB just gives the data and lets us make our own conclusions.
Was it a firmware quirk or a bad production run / sub par parts used in manufacturing?
I've only gone back a couple of weeks and may go back further, if I have time. But, for now, I'll do my best to add new cases as they come in.
What I've done is created a thread on my company's forum listing Seagate DM (and variants) cases. Perhaps, as the list gets longer, we can extrapolate the exact models to avoid.
http://www.recoveryforce.com/forums/viewtopic.php?f=12&t=157
