1. Accel - Chrysler/Dodge/Plymouth: 1961-72 273-440, single contacts, 1972-89 318-440, points ignitions, replacement cap
2. Exedy Organic Clutch Kit: 08-800
3. Chevrolet: 1957-95 262-400, gear drive
This Edelbrock Accu-Drive gear drive won't stretch or wear out. It provides up to eight degrees of cam timing adjustment in two degree increments, has offset bushings for easy cam indexing, and SAE 8620 steel gears that operate at higher rpms. This Accu-Drive will fit under your stock timing cover and has that "gear whine" sound we all love. Minor machining to the engine block may be required.
4. Flowmaster 52456 SUV Performance Muffler
5. FORD RACING 3.73:1 RING GEAR AND PINION SET
6. Holley Model 4175 Four Barrel Carburetor
7.Chevrolet: 262-400, 2.02 in. head diameter, stock length, intake valve
Milodon's Megaflow competition valves are forged from one piece of 21-4N stainless steel, have swirl polished heads and undercut stems for flow, and tulipped under head areas for weight savings. With hardened stellite tips and 1600 degree F temperature capability, they withstand high valvetrain loads.
8. Honda Power Stop Brake Pads
9. Summit Racing GM: 1973-86, non-metric engines, aluminum, chrome plated, 63 Amp, one wire, alternator
10. Keith Black/Silv-O-Lite Chevrolet: 350, .030 overbore, 3.48 in. stroke, 5.70 in. connecting rod, flat top, hypereutctic, piston
How'd I do 😛
