Not sure if this is the correct place to ask, but I'll give it a shot.
So I am in the market for an inexpensive wireless b&w laser printer. Under 150 preferably, even better if its under 100. Don't really care if its an all in one, mostly i just want to be able to do some occasional document printing. Speed and quality are not that important as I print maybe one or two things a month if that. Connectivity and dependability are more important. Also, I never had much luck with inkjets, as they run out or dry up at the worst time.
However, it has to work with an apple phone, two android tablets, one android phone, and two desktops. I know there is some software I can get to do airprint, but not really sure about how android does theirs.
Any suggestions?
Thanks.
edit: footprint is also important, the smaller the better
Any suggestions?
Thanks.
