Azureus will not load!
homestarmy
WinXP. When I try to run Azureus, nothing happens. It opens up as a process, but nothing. I have uninstalled it (noticed it didn't take most items away) and reinstalled, same. Deleted all files under /program files/azureus, reinstalled, same. Reinstalled to another location, same problem.
I also tried reinstalling java.
Any ideas?!
Otherwise, what other program should I use for my torrents? And I should be able to pick up where I left off with the torrents in another program if I can't resolve this, right?
Thanks so much for anyone who can help.
BitLord is good, but I personally use Azureus. It might be a problem with Java or an I.P. problem. Are you using a router?
Well I went to java.com and downloaded the newest version.
Also, nothing has changed with my router, it is a WRT54G and has been running with Azureus for months and months. The only change recently was running with a no-ip.com client, but it won't work even when that is closed, and it appeared to work fine after I started using it.
Also, for the meantime, I downloaded ABC. My issue with that is that when I click on a .torrent file on a website, nothing happens, although it is set to open with ABC. I have to right click on the link, copy shortcut, then go to file, add torrent, from URL, and what I have copied is already there. Ideas?
Maybe it is some kind of a network problem. My comptuers can no longer share files, and I cannot run through the network setup wizard, it is giving me an error. Any ideas?
Also when running the 'netsh int ip reset reset.txt' command it gives me:
WARNING: Could not obtain host information from machine: [OFFICE]. Some commands may not be available.
The network location cannot be reached. For information about network troubleshooting, see Windows Help.
