AX-7 and 4000rpm, 46.1cfm Delta good combo?
KentW
I just ordered the AX-7 from the Heatsink Factory. I already have an 80mm Delta, 4000rpm, 46.1cfm fan. Should this be a good combo for my 1800+? The fan is rated is 40dba, so it shouldn't be that bad. I'm trying to keep the noise reasonable! Thanks, Kent 🙂
I
<< The fan is rated is 40dba, so it shouldn't be that bad. I'm trying to keep the noise reasonable! >>
I hope that you have good sound 😉
I have a Delta 60 on my T-bird 1.2 @1.3, It is VERY loud, I'm putting a rheostat on it, good cooling, but very loud.
