what should the average temperature be for a cpu? i have a machine with a k6-2 380mhz not overclocked, running at correct speed, and its at 116 degrees F. i took note of this because the machine also does not run for crap, incredibly unstable with any os i've had on it. win2k wont install, mandrake was unstable, red hat wouldnt install, suse wouldnt install, a grip of other linux distros wouldnt either. its running win98 now, and reboots itself for no good reason sometimes and it takes about 8 reboots to get it to boot properly the first time.
so i'm thinking, maybe the cpu is overheated. i'm using a standard fan, but i did not use that glue to attach the fan to the cpu.. could that possibly be the source of all these problems?
