Auzen X-Plosion Driver Problem
HorseShoe
165
Hi guys, didn't exactly know where to post this, so just going to post it in here.
Basically I tried out Windows 7 Beta and found out that my Auzen X-Plosion driver doesn't work with it, so I was just wondering if you guys knew of any solution to this problem because I was under the assumption that programs that worked with Vista would work with this new OS as well.
Any help much appreciated.
techmanc
1,212
7
Remember its still in early Beta so there a lot of bugs in it I wont use it except in VMWare or testing on separate hard drive using my removable drive bay
BigNaj
I have the same soundcard. You have to do it manually. Download the latest driver and unzip it. Then go to device manager and you will see your soundcard with a yellow question mark. Right click on it and then hit "Update Driver" Select from location on computer and browse to the unzipped folder. It will install the driver and you are good to go. I havent yet run into a vista driver that wont work with Windows 7. Sometimes you just have to install it manually...
HorseShoe
165
I will definitely try that, I just tried to install it by just clicking on the setup and letting it auto install when I downloaded the driver from their site.
Will let you guys know how that works out.
