AUX power connector on PSU. What Is it for?
thorin
anyone find a use for it?
Yup lots of anyone's have. RTFM and you'll find the answer too :p
:D
Thorin
Kenazo
10,429
rtfm? If you mean "Read the fvcking manual" that doesn't help, b/c the manual says nothing. :)
I'm just curious what sorts of devices use it.
mrbios
331
The only time I've ever seen the AUX power connector used is on RAMBUS motherboards. OH, and I think I've seen it on a server board we have here at the place I work. It's pretty much useless these days, but I think it's required to be compliant with the ATX specification.
Viper96720
4,390
Motherboards
Rukkian
135
Pretty much every P4 motherboard needs it and many of the Amd boards are now using it.
Budman
He's not talking about the 4 pin P4 power connector,he's talking about the flat one that looks like half of an old AT power connection.
Those are rarely used on desktop board mostly dual cpu boards & servers use it.
HappyCracker
939
I have an old Dell XPS-R (Dec. 1998) that uses it. Other than that, I've never seen another machine that needed one
mechBgon
Oct 31, 1999
30,699
Asus A7M266-D has a fitting for it. Bigger picture: coil it neatly and stow it out of your way :)
footbal07
270
it kinda looks like the plug on the 1.0 xbox. when i sleeved my psu i just cut it off seeing no viable use for it.
jjyiz28
2,901
it gives the mobo more consistent power for 3.3volts and 5volts. 2, 2, and 2 ground wires
