- Jun 17, 2001
- 55,420
- 1,600
- 126
I removed some extra info from your op... Look at the rotor material differences.
Wow. Thanks. I guess at the very least that settles THAT debate. I actually thought you edited that in a FTFY kind of way.
So I ended up getting the parts from Napa. I reserved the parts online using their parts finder.
Took off the wheel and shit today to do the job and....rotors are too big and brake pads are too small. WTF?
One should also refuse to accept boxes that show tampering. I've had boxes where I suspect someone returned a lesser-value rotor inside.That's really obnoxious. Generally when this happens I've found it's from an idiot employee looking up the wrong make/model or part number. I like to look them up online before I go in.
What'd you end up doing?
Just out of curiosity, how often do you guys typically change out rotors?
I change rotors when they warp. They seem to last roughly as long as the street pads before warping.
On the S2000, I change track rotors when they split in half (symptom of inadequate cool-down puttering in the pits after a session), or when they develop so many hairline cracks that I don't think they will last a day. Hairline cracked rotors become street rotors.
I did research on the difference between the two. Seems pig iron and scrap steel is a alloy. Iron alloy is well, a alloy.
Although there is really nothing incorrect in what you said, I can't say that it captures a metallurgical analysis of the situation.
btw-the crosshatch pattern on rotors is a remnant of them using a segmented rotary grinder (like a Blanchard) to finish the rotor and is considered to show flatness (a good thing).
I am not so sure in the case of these rotors that one alloy is superior over the other.
