Not true. Automatics engage the clutch when you are slowing down (essentially going into neutral). You will see the engine idling when slowing down, not RPM's decreasing -> downshift -> RPMs decreasings (and so on and so forth until neutral).Originally posted by: AgaBooga
Why would you do that? By leaving it in Drive you get help from the engine braking as well as brakes
Originally posted by: GoHAnSoN
i heard that the transmission might be "locked" and stuck forever if you swift to "N" during "D"
Nah, not true. The only thing that locks in an automatic transmission would be a torque converter (if it was a lockable torque converter), but that will not lock you out of Drive from Neutral, it just allows there to be no slip in the clutches when you reach a certain RPM (in an automatic transmission, there is almost always a decent loss of power in the transmission due to the slipping that occurs with all of the clutches).Originally posted by: GoHAnSoN
i would like to know whether it's really will hurt the transmission.
Hah, no way.
A transmission can get locked for other reasons (running low on the Automatic Transmission fluid, something breaks, etc...). Read my post, it shouldn't do any harm. Now neutral dropping a car will do some harm, but shifting into neutral while slowing down shouldn't help nor harm.Originally posted by: GoHAnSoN
Hah, no way.
how true ? cos i heard real cases where the tranmission got stuck, maybe it's just highly rare ?
but is doing this a healthy to the car?
Originally posted by: mAdD INDIAN
I also heard that hwen you are in neutral ATF fluid does not get dibriubted evenly over the tranny.
However I do not know if this is true or a myth?
