Auto shutdown question.
SithSolo1
7,740
11
My friends just upgraded to XP from ME and now his computer won't automatically shut itself off when he selects shutdown.
Is there anyway to fix this?
Colt45
19,720
hmmm.. IIRC, WinMill uses APM for autoshutdown. Win2K/XP use ACPI.
so.. Check if ACPI is enabled in the BIOS. Enable it if it isnt. Problem is, if XP was installed with ACPI disabled, you will have to change the HAL. I'm not sure if this can be succesfully done without reinstalling.. but if it can:
go into device manager, click on 'computer' (might be 'system').
It should say something like 'ACPI computer' or 'APM computer'.
bring up the properties for it and change the driver to ACPI computer.
This is, of course if ACPI is disabled in the first place :p
How old is the rig anyways? If the motherboard is pre-BX (the mid-PII era) then chances are it doesnt support ACPI.
Edit: almost forgot.. before you try what i said up there ^, go into control panel, then power options. There might be a check box that says "Enable APM{ACPI?}" If there is, that should do it.
does the computer have a sleep/standby function working correctly?
SithSolo1
7,740
11
Ok on mine its says ACPI but on his its says StandardPC and he can't change it.
tbalon
419
This is from the ACPI trouble shooter:
During Windows Setup, ACPI is installed only if all components present during Setup support power management. Some components, especially legacy components, do not support power management and can cause erratic behavior with Advanced Power Management (APM), or may prevent ACPI from being installed. Examples of such components are Industry Standard Architecture (ISA) components and an out-of-date BIOS.
Does that help any?
tbalon
419
Here is some more info:
Windows XP and Advanced Power Management (APM) Support (Q307525)
The information in this article applies to:
Microsoft Windows XP Home Edition
Microsoft Windows XP Professional
SUMMARY
This article describes how Windows XP installs Advanced Power Management (APM) support.
MORE INFORMATION
Windows XP supports the following two methods of power management:
Advanced Configuration and Power Interface (ACPI)
ACPI is the preferred method for controlling power management. When ACPI support is not installed, Windows XP installs APM when any of the following situations occur:
The computer appears in the Auto-Enable APM list section of the Biosinfo.inf file. The computer passed APM tests and should work with APM. The APM tab is present and enabled in the Power Options tool in Control Panel.
The computer appears in the Disable APM list section of the Biosinfo.inf file. The computer is tested and found to have problems with APM. The APM tab is not present in the Power Options tool in Control Panel.
The computer does not appear in either of the lists, and is considered neutral. The computer is not tested for APM support in Windows XP. The APM tab is present in the Power Options tool in Control Panel, but it is not enabled by default. To configure this option:
In Control Panel, double-click Power Options .
On the APM tab, click Enable Advanced Power Management Support .
Microsoft does not recommend enabling APM support on a computer that is not detected as APM 1.2-compliant. If you experience problems after enabling APM support, disable APM, and contact the manufacturer for an updated BIOS. If a computer is a multiprocessor system, Windows XP does not install APM support.
For additional information about troubleshooting APM-related issues in Windows 2000, click the article numbers below to view the articles in the Microsoft Knowledge Base:
Q242495 Troubleshooting APM Issues in Windows 2000 Using Apmstat.exe
Q237673 How to Troubleshoot STOP Errors After Enabling Advanced Power Management
For additional information about troubleshooting an ACPI BIOS that is not being detected properly or for related issues in Windows 2000, click the article number below to view the article in the Microsoft Knowledge Base:
Q216573 How Windows 2000 Determines ACPI Compatibility
You can also refer to the ACPI BIOS lists at the following Microsoft Web site:
http://www.microsoft.com/hwdev/onnow/ACPI_lists.htm
