Need some help with this POS I bought for an old work truck. It's a 97 Jimmy.
The key won't turn all the way back to the off position so I can't remove the key. It ends up draining the battery all the way down. Then after I jump it, it starts fine and the key/ignition will work fine.
Called the local shop/thief and he says he will charge $300 to replace the starter but wasn't even sure if that was the problem. Said it could be 2 or 3 other things.
Any help would be greatly appreciated.
Thanks,
David
Thanks,
David
