- Sep 3, 2000
- 1,128
- 0
- 0
Not really a specific deal, but Audiotrak is soon distributing it's soundcards in the U.S. They have a Prodigy 7.1 soundcard with a VIA Envy24HT soundchip on it, suggested retail is $99. Same one as on the M-Audio Revolution 7.1 and the Terratec Aureon 7.1 Space. I think this card is the best of the 3. Has the necessary inputs (for me) like the CD/DVD ROM audio cable connectors, the digital one too. As well as the preferred (by me) coax digital (as opposed to the Terratec's fiber optic) input/output.
Check it out here:
www.audiotrak.net
Here are the features:
Experience High-Fidelity Surround Sound up to 7.1
Transfer up to 24-bit 96 kHz Pure Audio with Coaxial Digital Input and Output
Controllable Extended Input Connectors (Line, CD, Aux, and CD Digital) on Board
24-bit, 8 Channel 192 kHz Playback and 96 kHz Recording
Experience Stereo Audio Sources with Expanded 7.1 Channel Surround Sound
Emulate Multi-Channel Surround Sound with SRS TruSurround XT with Enhanced Bass and Dialog Clarity
Expand Audio Versatility with Advanced NSP featuring E-WDM and DirectWIRE
Plug In with Analog Inputs (2) and Outputs (8)
Independent Surround Sound Channel Volume Control
Enjoy High-Fidelity with Integrated Headphone Amp and Microphone
Pass Pure Audio Signals to Dolby Digital and DTS Decoders
Support Windows Media 9 with 24-bit, 96 kHz 6-Channel Audio
Support Game Surround Sound APIs such as EAX 2.0 and A3D
and the Specs.:
High-fidelity 24bit 192 kHz D/A converter; 106 dB Dynamic range
High-fidelity 24bit 96kHz A/D converter; 102dB Dynamic range
24bit 96 kHz Digital Coaxial Input and Output
Analog 2 In / 8 Out;
-10 dBV unbalanced 1/8" (3.5mm) mono and stereo input and
4 x stereo -10 dBV unbalanced 1/8" (3.5mm) output
2 channel recording and 8 channel playback at the same time
Supports multiple sampling rates : 44.1 kHz up to 192 kHz
Full Duplex - Simultaneous record/playback
Uses 32bit PCI slot: PCI bus-mastering support
Microphone preamp with +5V phantom power
Headphone amp
Supports the E-WDM driver:
WDM and ASIO 2.0
Direct KS support for SONAR
OS: Microsoft Windows XP/2000/ME/98SE
Check it out here:
www.audiotrak.net
and the Specs.:
Headphone amp
WDM and ASIO 2.0
