AudioSource SW Fifteen 200-Watt Powered Subwoofer $149.00 shipped
Pliablemoose
25,195
Thanks for the heads up, I believe there's a couple of $5 coupons out there and free shipping is available:D
Feb 10, 2000
30,029
67
Thanks for the tip! This is very tempting (my old 8" Miller and Kriesel sub is dying), but I am still thinking about ponying up for a more serious sub, like an SVS 20-39 PCi or Hsu Research VTF-2. Decisions, decisions . . .
Ah - what the heck - I went ahead and pulled the trigger on this. According to the reviews at Audio Review, this is a steal, and can be easily improved significantly by adding $4 in fiberfoam sonic padding.
hdj
I have this sub, and I must say that it's great for effects and such. NOT a great musical sub. Lining the inside with dampening material certainly improves it's musical capabilities.
lungster
392
Check your Gold Box. It was in mine and had an additional $22.48 off for a $127.40 final price. I'm gonna skip though. Nice deal nonetheless.
Feb 10, 2000
30,029
67
I checked for it over the last few days and never found it, just the usual assortment of gardening shears and wineglasses. If it is there later, when I can re-open it, I will cancel my order and re-order it from the Golden Box.
Fritoz
350
Freakin' worthless gold box... How many people impulse buy cheese graters, anyway...??? :confused::D
Wolverine27
2,350
I tell you...they're marketing geniuses over there at Amazon...LOL!
Snyder81
460
I impulse bought this sub. I figured for $133 shipped after tax it was well worth it just to have an extra sub sitting around. I'd like to compare this to my 15" powered JBL 350W subwoofer.
Goosemaster
48,775
All you need to know:
with $60 worth of mods it is like a good $500-600 sub (still a tad shy of the performance of an M&K and that may be fixable with a high quality replacement woofer). How do you transform any regular sub into a superior one? Go to PartExpress.com, order (8) 10x10" sound deadening sheets (part# 268-010) to cover all of the open wood panels, order 3M Spray 74 Super Foam Fast Adhesive (part# 340-270) to be able to attach (2) rolls of acoustic foam 1-1/2" 24x18" squares [scissors easily cut the pieces in 8 equidistant rectangles] (part#260-316B) to the sides, top, and bottom of the previously installed deadening panels. Next turn the box over, and install the Dayton Audio Black Chrome Speaker spikes (Part# 240-715) you ordered to de-couple the sub from your carpet, hardwood, or vinyl floor. The hole for the speaker spikes are basically prefabed for your where Audiosource notched in the spots to place the screws to hold those cheesy rubber feet. The spike set includes floor protectors for those with/out carpet floors in your listening area. Finally, return that cheesy piece of insulation that was placed inside the sub back into the enclosure, but take scissors cut it in half and partially block the rear of the port (these cheap style ports weren't designed to avoid port noise). Now, reseal the speaker or a new 4 ohm driver of your choice back into the enclosure using speaker sealing caulk (part 269-300) [tacky, rubbery type compound that is moldable and has no perceptible odor] to absolutely seal off any air leaks. Set the speaker upright in your desired listening location, balance the box to insure absolute sturdiness, and prepare to be blown away. The
:cool:
You're welcome
EDIT: Heh, my post count is 2-3-4-5-:cool:
Goosemaster
48,775
You fools...:|
You bought all of them before I had a chance to..
Anyone know where I can get one of these now and not get ripped a new one...lowest price I've found now is $179:(
