audiophiles please help me understand something
IKeelU
137
1. What exactly are the benefits of having a Dolby Digital encoder in my system (isn't a decoder necessary to get 5.1 audio)?
2. My CNR card has three jacks: one SP/DIF, one labelled C/W, and another labelled R. What do each of these jacks do? Note that those labelled C/W and R are not SPDIF connections (I don't know what they are).
3. I heard that the SPDIF can be used to send an undecoded DD signal to a decoder, which then seperates the signal into 6 channels. Since the DVD already contains a "coded" DD signal, couldn't any sound card (not just high end) sport one of these? After all, isn't the SPDIF simply transferring an already coded DD signal to a receiver?
4. I am asking this because I want to know how to get the most out of my nForce sound chip. It is currently plugged into an old HK amp via a stereo-to-RCA cable, which amplifies two floorstanding speakers. If I want 5.1 sound, what kind of speakers should I get, and where would I plug them in?
Thanks for any help.
nord1899
2,444
The benefit would be that all sound sources in your computer could generate a Dolby Digital 5.1 sound stream. This would allow games to do it, music to do it, etc... As encoding takes up a fair amount of CPU time, having a dedicated processor for it is helpful. As for decoding, that only matters if you are sending the signal to a separate system (external decoder box, home theater system, etc...) See answer below for more ...
SP/DIF stands for Sony/Philips Digital Interface. I am assuming you have the COAX version rather than the optical. The optical is usually called TOSLink (Toshiba Link). The SP/DIF would allow you to send a raw signal to an external sound system, typically a home theater setup. Music would be encoded as PCM (Pulse Content Modulation I think) which is similar to the WAV format, which gives you stereo output. DVD's would send out an encoded Dolby Digital 5.1 (or even possibly a DTS) signal. Assuming the external sound system can decode them, you have no problem. The C/W is probably the Center/Subwoofer channel and the R is the rear channel. These are for sending 5.1 analogue signals directly to a speaker system, for example Klipsch ProMedia 5.1's. The front channel is probably on the motherboard up by all the PS/2, serial, USB, etc... ports. Oh and the actual plug types are the following: SP/DIF is COAX or RCA (interchangable), C/W and R are both 1/8" mini.
Yes, the SPDIF sends an undecoded DD signal to a decoder. Yes some sound cards out there are able to decode DD signals (I think the Audigy can amongst others).
You have two options then. First, get computer style speakers that have the 3 mini plugs (again, Klipsch ProMedia 5.1, Logitech Z560's, etc...). Then plug in the appropriate connectors and there you go. Second, get a home theater receiver that supports at least DD 5.1 decoding and use the SP/DIF connector to send it the info. You would then hook up speakers to the receiver. These speakers would not be computer speakers.
No problem.
EDIT: small clarification
