I'm having some trouble with Audiocast (ver 3.0.1) on my home stereo system. The device seems to work OK on the 2.4GHz band, but I would like to transfer it to operate on the 5GHz band. My router is a Netgear R6300. I am able to communicate with it using my Android phone and also an Apple iPad. I can use either of these, running Spotify, to successfully play music.
As I understand from Audiocast's somewhat sparse instruction sheet, what I am required to do is to enter the Audiocast device's setup, which the instructions say to use the phone (or the iPad) to connect to a wireless network named "Audiocast_XXXX", and after joining this network to use a browser and go to IP address 10.10.10.254. According to the instructions, this should get me into the setup screen for the Audiocast device and allow me to configure it to operate on the 5GHz band instead of the 2.4GHz band.
Here is the problem: whether I use the Android phone (Chrome browser), or the iPad (Safari browser), to attempt to go to 10.20.10.254 the result is a "connection_timed_out" message. Both the phone and the iPad appear to attempt to connect for a minute or two, but a connection is never made and the "connection_timed_out" message is sent.
I don't know if I'm doing something wrong, or if the device is at fault. For anyone with experience with this device, I would certainly appreciate your advice. Please help if you are able. Thank you
