Originally posted by: coolkatz321
What I am trying to say is... you know those audio video selectors you can buy at a place like Radio Shack? Do they have those for the Line in thing I'm talking about.
Ok, I'm confused now...
When you said "L and R inputs into the one audio input" I assumed you just said input instead of output...
(as in I took it to mean you got an adapter that takes the red and white RCA outputs from the xbox and changed it into a standard 1/8" male or female connection like your comptuer speakers use).
Is that the case or not?
What "line in" are you talking about? The only line-in I'm thinking about is the one on your computer.
So, do you have 1/8" input on your speakers
1/8" output from your comptuer
1/8" output from your xbox
and you want to be able to select between the two sources and feed them to the speaker input?
EDIT:
like
this?
