I have a sound rack with 8 audio outputs, and a 5.1 HT speaker system (powered by a Sony receiver). I am looking for a program that will allow me to output stereo music to 2 stereo sets (fronts & surrounds), and preferably a mono version of the music to the sub channel and center channel (center channel is certainly not necessary)... this means I need to be able to assign at least 5 channels of audio to my choice of outputs. I am willing to use any method necessary to do this... thus far I have only been able to find software that uses 2 stereo sets (fronts and surrounds, without the sub). A program that can use ASIO is preferred.
I know I can do this with Winamp using multiple instances (3 instances), but I don't know how I can control all the Winamp instances simultaneously so that the music playback is in sync. A means to do this would also work.
It would be easier if my receiver (STR-DE875) had an option for unprocessed audio to fronts/surrounds/sub, but I have only been able to configure it for fronts/sub if the signal is to remain unprocessed by the receiver's DSP, so I have resorted to using the Multi-Channel-In option.
I have spent many hours researching this, and any help will be appreciated.😕
