So I axed this question on AVS forums but didn't get a satisfactory answer.
Suppose you have two receivers. A is rated 100W into 8-ohm speakers, B is rated 100W into 6-ohm speakers. If you switch the two, and use A to drive 6-ohm speakers and B to drive 8-ohm speakers, which will sound louder at max power? Assume power ratings are calculated in an equivalent manner for both receivers.
Anyone know the answer?
