Audio Problems...
czech09
I have a Neo4 Plat SLI mobo, well I finally got the onboard audio to work but my audigy 2 value won't budge; moreover when I install the audigy drivers the onboard audio stops working as well. I've tried downloading x amount of drivers for both as well as trying to change the PCI slot the audigy is in etc and nothing seems to have worked, anyone have a clue?
I don't think you can use both audio at once. Either onboard or add in card. You need to disable the onboard on in the bios if you are using your Audigy.
Mmm both worked fine on my Dfi Lanparty at the same time, I did what you suggested and that still brought no success 🙁
