- Oct 21, 2001
- 2,058
- 1
- 81
I have a Shuttle AN35N with an odd sound problem.
I built this for a friend a couple of years ago and left everything stock, including the OB sound. I set up dual boot with Win2K and XP Pro. The OB sound was working fine then, and recently she said XP was hosed and the sound stopped working.
Got it back today and here's the deal.
From Win2K or XP all I can get is left channel sound, and it's choppy. I installed new drivers from nVidia's site but it change a thing - still left side only and choppy in both OS's.
I figured the OB sound had died so I installed a SB Live that I had and there was no change. It still has the same choppy left channel sound from either OS. I've tried new drivers from nVidia and then from Creative, deleting one before installing the other.
The PC was full of spyware and several viruses. A scan with Webroot Spysweeper, AVAST and then Trend Micro cleaned the crap out- at least all the crap it found. There are no conflicts in the DM and it now boots clean with either OS, so I am down to wiping the drive and starting over as a possible fix but thought I would see if this problem sounded familiar to anyone before I take that step.
Yes, the speakers are fine. Any suggestions before I pull the trigger on the format?
Thanks!
Thanks!
