I get no audio output through HDMI on the following boards:
H81M-ITX/HDS
B85M-ITX
Z87M Extr.4
Although they work through DVI you still need a convertor from DVI to HDMI if you only use HDMI-HDMI cables. For HTPC this is a nuissance.
The Asus H81T works ok through HDMI.
