Audio on Asus P4PE -- 2 questions
sickNtired
818
Okay, first question.
I am currently using the onboard audio which sounds good. However, I would like to have more treble. I notice that under the advanced settings tab in the "Volume control" panel (that you get by the little speaker in the tray), the controls for bass and treble are greyed out. Any way to adjust these things?
Second question:
I am interested in the Audigy 2. I really like that I finally have a MB that does STR (Suspend-to-RAM) standby properly now. Is there anybody usine the Audigy 2 that is having any problems with STR standby working correctly?
By the way, here are my specs:
WinXP Pro, Asus P4PE with the Gigabit LAN and SATA, Intel P4 1.8GHz oc'd to 2.4 GHz, 512MB Corsair DDR400 PC3500 C2 RAM, ATI Radeon 9700 Pro, Hauppauge WinTV-250, 2 WD1200JB HD's, 1 IBM 75GXP 75GB HD, Lite-On 48x12x48 CDRW, Pioneer A04-
gonzo2k
2,433
webpitstop.com
I'm using the onboard audio on the same board and the treble/bass controls are also grayed out. There is a "bass boost" option under options/properties from the Volume control panel that you can uncheck. This may help with your treble.
andrey
If you'll look at my system specifications, I have Audigy 2 on Asus P4PE.
My Suspend-To-Ram, Sleep and Hibernate features work perfectly in Windows XP and I have never even encountered a problem with either feature.
Feel free to PM me if you'll need any additional details or info.
Best regards,
--Andrey
