Audio nub, need help with what cables I need
Tiamat
14,068
you need three cables that are stereo 1/8" male to stereo 1/8" male. Match up the colors and it should be fine.Make sure you update your motherboard's sound drivers and set it to 5.1 analog out.
Edit: dont worry about the blue green pink ports on your mobo as they wont be used with your spekaer inputs for the speakers you have. The cables can be found at Radio shack, bestbuy, monoprice.com, etc. and they are very common.
Shawn
32,236
53
you can get them cheap at monoprice.com, but if you want them now Radioshack carries them.
