Originally posted by: joshsquall
Originally posted by: Tiamat
The only catches to your situation that I see is:
1. Budget is not infinite (not really a problem)
2. Left side wall is bare and will shift the stereo image to the left due to reflections and since the right side is open without the same reflection.
More questions:
1. Do you WANT surround sound, or do you want a higher quality 2 speaker + subwoofer option (or 3 speaker + subwoofer)
2. Are you against shifting your whole room setup 90 degrees counter clockwise so that the windows are to your right and the couch divides the kitchen from the living room? This setup would allow for better stereo imaging without a shift in either direction. As long as your couch is between 62% and 66% of the way in between the front and rear walls (in whichever orientation), you optimize the smoothness of the bass due to minimization of interaction of bass modes.
1. I'd at least like the option to upgrade to 5.1. 3.1 for now is okay.
2. I'd prefer to keep it open, so I may just have to live with the poor audio profile of the room.
no problem with 1. This will involve picking out a receiver and trying to get a grip on the type of speakers that match up with your subjective liking.
2. Read my edit. There are other options so that you don't suffer "poor audio quality". The room does have a big control over the quality you can expect, but, there are options out there to help.
If you cannot expense the tapestry, you can wrap the panels yourself in cloth, or you can buy premade ones at a place like
Gikacoustics. The first link I showed actually is somewhat affiliated with gik in that the owner of the first link works at gik. For about 130$, you can get 2 4" panels to hang on the left wall in between the couch and the speaker position. Angling the speaker towards the listening position rather than pointing straight out will also help in this regard.
Also, What are your bass needs, what do you expect when you hear bass. This would make the difference between suggesting a 200$ subwoofer or a 450$ subwoofer.
With regards to speakers, there are several 300$ per pair speakers that are good entry level speakers. Notably, the Paradigm Atom v.5, the AV123 ELT525M, offerings from Infinity, etc. Paradigm would have to be found at a local dealer (just got to
here). AV123 can be found online
here. Infinity can be found on crutchfield.com or amazon.com etc.
