Audio missing?
aakerman
436
I have an asrock 939dual-sata2 motherboard, which includes an 8 ch audio solution.. which I guess is manufactured by realtek (ac97).
Uptil now I've been using a pci-soundcard. It is, however, causing my pc to shut down, so I have disabled it and now I want to use the onboard card.
But - I can't find the onboard card anywhere.. it's not listed in device manager (not even with a red cross), and nothing happens when I install the newest AC97 drivers. What to do?
device manager ss
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
Is it enabled in BIOS? It might have gotten disabled since you had the add-in card.
Boyo
1,406
You have to go into BIOS to configure onboard sound. If you were using a PCI soundcard, then your onboard sound was disabled presumably. Go into BIOS and turn it back on.
