Audio issues w/ Max Payne 2
dmw16
7,608
I just got Max Payne 2 and I am having some sound trouble. I can't hear a lot of sounds. Like when Max should be talking he doesnt make noise and also, the guns when I fire make little to no noise. Any ideas?
thanks,
-doug
Nebor
29,582
12
I also have general sound problems. SOmetimes voices are very quiet... but the biggest problem is, some cutscenes voiceovers are somewhat staticy. I can understand them, but it sounds like ass.
DefRef
4,041
A patch is needed. IGN mentioned problems with both Audigy 2 and Live 5.1 sound cards. Nice QA work there, Rockstar. Didn't you think to test it with something other than an AudioPCI?:|
Nebor
29,582
12
I fixed mine by disabling multichannel sound. It's noted in the manual that you should only enable it if you have a 5.1 system or greater, a center channel is required.
jiffylube1024
7,430
Yeah. Disable 5.1 sound, and possibly also disable EAX. That should get spoken voices audible again.
elkinm
2,146
For me all backrond voices and most voices I talk to in normal play are high pitched and go very fast. Almost imposible to understand and read even with subtitles. I have the same problem with UT2K3 and Unreal II if I enable 3D hardware acceleration. With software everything is fine. Anyboudy know of a way to fix this problem in general or is there a way to dissable hardware acceleration.
I also sometimes do not have audio that I should be having. Sometimes I replay a scene a few times and get different results dew to the audio heard.
The strangest problem I have is that sometimes the cut scenes do not play at all and sometimes they play, but pause when they reach the next page rquiring a stop and play to resume the playback. And sometimes it works fine. Also if I get were I can play the cut scenes, I can go back and play scenes that would not play earlier so I don't think it is file courruptin.
Anybody else notice these bugs and know how to fix them?
Thanks
bignateyk
11,288
7
Yeah i had minor sound problems. I, too, thought it was my sound card. I have a chaintech 5.1 sound card, using 2.1 speakers. For the most part it was fine, but every once and a while the volume would go down for a few seconds. Also, during heavy fighting, sometimes i would get crackling.
As for the ending, I thought it was pretty easy. The only hard part is getting up that damn handicap ramp without getting wasted.
