audio interference on my CB radio due to engine noise
MrDudeMan
15,069
94
how do i stop this? whenever i hit the gas it makes a really loud hissing noise through the speaker...wtf?
what kind of filter do i need to buy?
mikable
303
check your spark plug wires, then your plugs. if thats ok you might have a bad diode in your alternator.
Other then that you might want to ask on a CB forum you can try World Wide CB Radio Forum They'll set you up good!
MrDudeMan
15,069
94
i think i have a bad diode in the alternator anyways...
when the battery dies, once i finally get it started, the second i let off the gas it does if i havent run the truck for at least 20 minutes to recharge the battery
im pretty sure that means a dead diode
the same radio did the same thing in another car though, so i dont think that is the problem
