Originally posted by: Fausto1
I'd like to run some wire through the attic to speakers I have mounted over the back patio. It's looking like 50-70 feet of wire per speaker......any reasons this might be a bad thing? Just curious.
So it's only bad from a sound point of view? If that's the only thing then no worries since these are just cheapie outdoor speakers for parties and such.Originally posted by: glen
Yeah, it is bad and easily measurable. However, moving your head left or right 2" will have a greater effect on the sound. So, don't worry about it.
Originally posted by: sohcrates
just use at least 16 gauge wire and a run that length is fine
Thats what I was thinking.Originally posted by: sohcrates
Alrighty. I can handle that. I guess what I was most worried about was any extra load on my new receiver via the longer cables.Originally posted by: sohcrates
Originally posted by: rahvin
You should ask this question at the AVS forums, all the 16 year old "experts" will give you a ton of different respones.
From what I have seen in my cursory browsing while rewiring my homes low voltage you probably want 14/2 for clarity, but 16/2 should work fine.
Can anyone explain how ABUS audio works?
The question should be at what length does the interference become noticable enough to be annoying and why pay for 12 if 14 will work.![]()
Because impedance varies with frequency and hence the level of attentuation .1db or 2 db differs. For examply my speakers drop to 1 ohm and an extra .2 ohms of impdance or resistance is a big deal.
:beer:
:beer:
But couldn't we assume that with outdoor grade speakers the quality of the speakers will be less than stellar and the attenuation of the cables might not even be noticable? :beer:
