Audio equipment - Mainly speakers ...
Safeway
12,075
11
I am putting together something for one of my courses, and I'd like to know what company sells the top of the line, most expensive audio equipment available.
Please list the company and how much a set of towers would cost.
Thanks.
clarkmo
2,615
You'tr gonna have to dig a little. Just asking folks to post a price list doesn't exactly qualify as research. Go to stereophile, audiokarma.org. audiocircle.com and just basically search. Martin Logan makes expensive speakers. So does B&W. there are speakers that are only built to order and very expensive. MacIntosh makes expensive gear but so do a lot of other companies.
I can't believe you actually asked for a price list, model# and cost. Like sombody's actually gonna do the work for you. Google...
AgaBoogaBoo
26,108
lol, there's never any end, you HAVE to specify a price range
Search around on audiogon.com and avsforum.com
Safeway
12,075
11
I found the German Physiks $250,000 Gaudis tower.
Claims to be the most expensive in the world.
Apex
6,511
www.gotapex.com
The Kharma Enigma is the most expensive pair of speakers I can think of at $1 million (picture is of system in some guy's "cellar" in Belgium:
Kharma Enigma
Wisdom makes an expensive set:
Wisdom Audio "Infinite Grande"
That 2-channel set is $600,000.
Few more:
Acapella Speakers Sphaeron Excalibur at $325,000
Magico Ultimate at $229,000
Wilson Audio (makers of the $225,000 WAMM speakers) is apparently designing new speakers codenamed Arabesque, which rumor has it, will be >$300,000. I absolutely love their Alexandria X2.
YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
Aug 6, 2001
31,205
45
What kind of class is this? :p
Don't forget the amp, pre, cables, and all that jazz if you're just trying to rake up a big budget example :)
glen
15,995
After you ahve spend about $5,000 I don't think you get much mroe for more money.
spidey07
65,469
Actually that's when it starts getting good.
b0mbrman
29,470
Thanks.
Set of towers?
You could make your own much more expensively. Start with the Accuton pure diamond dome tweeters, move on to overpriced speaker cable and such.
Rubycon
Madame President
Aug 10, 2005
17,768
485
Actually the high end of the high end doesn't even use a voice coil or diaphragm any more. Amplifiers are water cooled and often powered on dedicated lines running to a utility substation and listening rooms are built with similar specification to nuclear reactor containment!
Get the checkbook ready and the 10 digit calculator you're going to need to balance it! :shocked:
Excelsior
19,047
18
Not really...maybe as far as overpriced/overrated speakers go.
Where it really "starts getting good" is DIY audio.
YOyoYOhowsDAjello
Aug 6, 2001
31,205
45
Didn't we have this thread already? :p
Excelsior
19,047
18
Sort of...I won't stop now though. :p
spidey07
65,469
I can't make electrostatic speakers and their supporting electronics at home.
so, neener.
glen
15,995
In my experience, DIY is a must for subs, but a bad idea for everythign else.
