SB Audigy 2 ZS
Win XP- 2 OS's one on one HDD, one on the Other. Problem only occurs on ONE system.
At boot up, Audio works completely fine but quickly goes away. Problem started when using BF2, sound would work fine until the main menu loaded then it would be gone.
Driver seemed to be fine and update, I reinstalled it though. Device Manager has it listed and working properly but If i go to Sound and Audio Devices Properties, the Audio tab no devices are listed. But in the hardware tab the card is listed.
What does NOT make sense is that there are 2 versions on windows on this computer and one runs absolutely fine, but the other one does not.
iTunes - At startup reports "detected a problem with your audio configuration. Audio/video may not operate properly."
WMP - "problem with your sound device."
Please help me out!.. no sound = no games!
