<< Are you doing anything while you're burning? I know the drive is has Smart-Burn technology, but doing something on your computer might be a factor. Also, which program are you using to convert your MP3s to WAVs? Try changing the program and see if that works. Hope this helps. >>
I think he is using Nero to do it all....should I have him use winamp to convert them first? >>
Sure, give it a shot. If he's using Windows XP, he can also try using Windows Media Player to make an audio CD.
