Audio Catalyst and W2K
ViperVI6
8
Every time I launch audio catalyst, it reboots my machine! whats up with that! Music Match does the same thing, I click it, and boom, reboot, has anyone else had this problem?
ericd
355
Will your machine actually rip songs on your machine. On mine with Audio Cat and Win2k it only gives me Analog as a ripping option. Win98 it functions just fine but on Win2k it screws up. And yes I am running SP1
BudB
Use it all time with Plex 8/20 and Plex Ultraplex 40. It even rips using the Pioneer DVD drive I have on the machine (but only at 10x not the 18x with the 40 max. This worked even before I installed SP1. Zero problems burning. Maybe it's the SCSI drives although the DVD is on the secondary IDE channel, primary drive and it works as described above. Don't know what else to say.
BudB
On second thought I think I may have had to load ASPI drivers separately but it's been so long that I can't remember.
radiocore
1,011
ericd
I had the same prob...but then i just had to DL the aspi chk thing and after all that stuff loaded, i could rip using other methods. just check the forums here, thats where i found all the stuff that i needed ;)
