joekingston
I've noticed while playing online games, sound effects are missing. For example, the sound of a gun reload will not play. Other times, sounds will play but cut off. Like the sound of a gunshot will play half-way through then silence abruptly. I also have problems with popping sounds and crackling sounds while playing certain youtube videos.
Googling my issue brought to my attention a couple articles about Creative sound cards behaving badly while sharing IRQ's. I do not own a Creative card but I assume the same principle would apply to me, so I decided to take a look at my IRQ assignments:
IRQ 0 System timer OK
IRQ 1 Standard 101/102-Key or Microsoft Natural PS/2 Keyboard OK
IRQ 3 Intel(R) N10/ICH7 Family SMBus Controller - 27DA OK
IRQ 8 System CMOS/real time clock OK
IRQ 9 Microsoft ACPI-Compliant System OK
IRQ 13 Numeric data processor OK
IRQ 14 Primary IDE Channel OK
IRQ 15 Secondary IDE Channel OK
IRQ 16 Intel(R) G33/G31/P35/P31 Express Chipset PCI Express Root Port - 29C1 OK
IRQ 16 NVIDIA GeForce 260 GTX OK
IRQ 16 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D0 OK
IRQ 16 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CB OK
IRQ 17 Intel(R) N10/ICH7 Family PCI Express Root Port - 27D2 OK
IRQ 17 Realtek PCIe GBE Family Controller OK
IRQ 17 ASUS Xonar DG Audio Device OK
IRQ 18 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27CA OK
IRQ 19 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C9 OK
IRQ 23 Intel(R) N10/ICH7 Family USB Universal Host Controller - 27C8 OK
IRQ 23 Intel(R) N10/ICH7 Family USB2 Enhanced Host Controller - 27CC OK
As you can see, my sound card is sharing a IRQ with my NIC, which would explain why I'm getting sound issues only during online play. That would also explain the mysterious issues I've been having with my internet that Comcast was unable to remedy.
First off, I have absolutely no way of manually assigning or altering IRQ's in BIOS, which is strange. There is a menu labeled "Cell" which describes "configue devices, IRQ's" etc. but entering the menu only has options to adjust CPU/DRAM frequencies. Weird.
There is an option to enable/disable ACPI but from what I understand, that can make my problem worse. Also, I've read that disabling ACPI does not work well on multi-processor systems, which I have and I'm sure everyone else does too.
The last thing, if you take a look at my IRQ's, IRQ 9 is supposed to be used by something called "IRQ steering" but I do not have that on my system. All options to manually configure resource management are either grayed out or completely missing in device manager.
So pretty much what all this means is, I have absolutely no way of changing my IRQ's in the BIOS or in Windows.
Changing PCI slots is not a option either. I am using a mini-ATX motherboard. It has a PCI-Express 16x slot (used by my video card), PCI SLOT 1 (completely blocked by my video card), and PCI slot 2 (used by my sound card).
Before I forget, I've already disabled both COM ports and my parallel port in BIOS. Also disabled both IDE controllers since I do not use any IDE devices.
So my question is, does anyone have any tips on how I can get my sound card to stop sharing an IRQ with my network card? Or should I just abandon this system?
