- May 2, 2005
- 203
- 0
- 0
Can someone suggest me some easy routes on getting the necessary/popular audio and video codecs?
Thanks,
Horace
Thanks,
Horace
Originally posted by: BigfootsMonk
I have Ubuntu Edgy, and it doesn't do the codec for me because I have an avi that doesn't have sound. I'm guessing it's too old already 0_0
Anyways, the universe and multiverse repositories, how do I enable them?
Is there a tutorial about this somewhere that I can just follow? Googled it for hours and didn't really get anywhere with it.
Originally posted by: drag
Depends on what paticular Linux distribution you choose.
For Ubuntu, for example, you want to enable universe and multiverse repositories. Then you want to install VLC and use that instead of the default totem. Also install win32 codecs, the package name varies but it's usually w32codecs or win32-codecs or something like that. Newer Ubuntu versions try to do this for your pretty much automaticly.
