Audigy Sound Card Question
LanceVance
I hear a lot of sites rave about Audigy sound cards for gaming. I use my PC for gaming, music, and occasionally multichannel music even though that is currently a rarity.
I currently have:
Speakers: Logitech 5500. This is a 5.1 setup and I have all speakers properly mounted/positioned. This system has built in Dolby Digital and DTS decoding.
EPOX Motherboard with onboard sound output. The speakers are connected by both an optical cable and 3 analog cables for complete 6 channel data (front left/right, back left/right, and center/sub). I can switch the between analog/optical connections on the speaker console.
Currently, completely discrete 5.1 3D sound works great in games and in DVD movies. I typically have to use the 6-channel analog to get discrete 3D sound from games and have to use the optical connection for DVDs with Dolby Digital (decoded on speakers).
What does an add-on Audigy card (or any other add-on sound card) offer me? I hate to spend more money and add another card and set of drivers to my system without a wothwhile advantage.
tiap
572
If you want to keep your system clean as far as software and drivers are concerned audigy should be your last choice, lower than your onboard.
Sounds like your fairly happy with your sound, so stay with it. I prefer your method, of using passthru and a good decoder/amp, even considering what little you lose in gaming form eax.
