AstroCreep
Hello all,
This is my first post here!
I'm hoping that someone might be able to help me out here, because I can not find the answer to this anywhere!
I just recently bought an Audigy 2zs (after I asked a Creative tech if what I wanted to do was possible and he said yes), and I'd like to be able to use my case's 'Upfront' audio ports (mic & headphone jacks) with this card.
I know that it's possible; people have told me that it can be done, you just have to have the proper pinout/diagram to do it.
Evidentially the place that I need to connect my case's 7 pins is going to be on either the 'AD_ext' (the big pinned-section used for the Platinum version's front panel) or the white 10-pinned-section in the upper left-hand corner of the card (when looking at the side w/ the chip).
The white pinned-section is a 'Proprietary connection' (words from Creative's tech support), and from what I've gathered on the net, it's a port that is used by OEMs when they put this card into their systems.
So my thought is that I would need to use the connections in the 'AD_Ext' or the mysterious white section...
Can anyone help me out? Or point me in the proper direction?
I appreciate it! 🙂
I appreciate it! 🙂
